소개
If your disk drive no longer works on your HP Pavilion 15-p046nr, you’ve come to the right place. This guide will walk you through how to replace your notebook’s disk drive. You may need to replace your disk drive if your computer fails to read disks entered into the drive or the drive refuses to open. You will need a Phillips size 00 screwdriver for this guide. Before you get started, be sure to completely disconnect power from your device.
필요한 것
Flip the laptop over so the bottom is facing up.
Place your finger on the top left-hand slide button with the lock symbol.
Slide the button to the right so that an unlocked symbol is visible.
Remove one 7 mm, Phillips #00 screw from the back panel.
Open the disk drive by gently pulling on the drive.
Pull the disk drive out and away from the device.
