주요 콘텐츠로 건너뛰기
HP Pavilion 15-p046nr Disk Drive Replacement
필요한 것
  1. HP Pavilion 15-p046nr Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Disk Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Disk Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Disk Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 3개
    • Remove one 7 mm, Phillips #00 screw from the back panel.
    • Open the disk drive by gently pulling on the drive.
    • Pull the disk drive out and away from the device.
결론
작성자
4다른 기여자 명과 함께
Betsabe Hernandez
회원 가입일: 09/18/19
835 평판
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 280
