주요 콘텐츠로 건너뛰기
HP Pavilion 15-p046nr Hard-Drive Replacement
필요한 것
  1. HP Pavilion 15-p046nr Hard-Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Hard-Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Hard-Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Hard-Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr Hard-Drive Replacement, Integrated Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement, Integrated Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Hard-Drive Replacement, Integrated Keyboard: 3 단계, 이미지 3개 중 3개
    • Remove screw covers from the hinge covers on the upper left and right side.
    • Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
    • Remove hinge covers by pulling up and out on the top of the cover.
  4. HP Pavilion 15-p046nr Hard-Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Hard-Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remove thirteen 7 mm screws from the back panel using the Phillips #00 screwdriver.
    • Remove three 5 mm screws from the back panel using the Phillips #00 screwdriver.
    • Grab the disk drive on the left side and pull the disk drive out completely.
    • Flip the laptop over and open the display.
  5. HP Pavilion 15-p046nr Hard-Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Run the plastic opening tool along the entire edge of the keyboard to separate the keyboard from the base of the laptop.
    • Gently lift the keyboard tray up.
    • Use care to lift the keyboard off of the device. The keyboard is still attached by ribbon cables.
  6. HP Pavilion 15-p046nr Hard-Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the two ribbon cables connecting the keyboard to the device.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the ribbon cable and gently pull away from the socket.
    • To reinstall, insert the ribbon cable into the connector and close the flap on the black line.
  7. HP Pavilion 15-p046nr Hard-Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Hard-Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the keyboard up and away from the device.
    • Removing the keyboard exposes the motherboard and its sensitive components. Ensure no tools or items are set on the motherboard or it could cause damage.
  8. HP Pavilion 15-p046nr Hard-Drive Replacement, Hard-Drive: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement, Hard-Drive: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr Hard-Drive Replacement, Hard-Drive: 8 단계, 이미지 3개 중 3개
    • On the bottom right corner of the mother board, use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the bottom two ribbon cables.
    • Grab each ribbon cable cable and gently pull away from the socket.
    • Uncover the hard drive by moving the bottom ribbon cable to the far right.
  9. HP Pavilion 15-p046nr Hard-Drive Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr Hard-Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the hard drive directly up and away the device, unplugging it from the cable interface as it's removed.
    • You will most likely need to remove the rubber hard drive enclosure and place it around your new hard drive as you reinstall the new part.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Betsabe Hernandez
회원 가입일: 09/18/19
835 평판
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 22
전체 시간: 689
