주요 콘텐츠로 건너뛰기
HP Pavilion 15-p046nr RAM Replacement
필요한 것
  1. HP Pavilion 15-p046nr RAM Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr RAM Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr RAM Replacement, Integrated Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement, Integrated Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement, Integrated Keyboard: 3 단계, 이미지 3개 중 3개
    • Remove screw covers from the hinge covers on the upper left and right side.
    • Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
    • Remove hinge covers by pulling up and out on the top of the cover.
  4. HP Pavilion 15-p046nr RAM Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Remove thirteen 7 mm screws from the back panel using the Phillips #00 screwdriver.
    • Remove three 5 mm screws from the back panel using the Phillips #00 screwdriver.
    • Grab the disk drive on the left side and pull the disk drive out completely.
    • Flip the laptop over and open the display.
  5. HP Pavilion 15-p046nr RAM Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Run the plastic opening tool along the entire edge of the keyboard to separate the keyboard from the base of the laptop.
    • Gently lift the keyboard tray up.
    • Use care to lift the keyboard off of the device. The keyboard is still attached by ribbon cables.
  6. HP Pavilion 15-p046nr RAM Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the two ribbon cables connecting the keyboard to the device.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the ribbon cable and gently pull away from the socket.
    • To reinstall, insert the ribbon cable into the connector and close the flap on the black line.
  7. HP Pavilion 15-p046nr RAM Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the keyboard up and away from the device.
    • Removing the keyboard exposes the motherboard and its sensitive components. Ensure no tools or items are set on the motherboard or it could cause damage.
  8. HP Pavilion 15-p046nr RAM Replacement, Motherboard: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement, Motherboard: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement, Motherboard: 8 단계, 이미지 3개 중 3개
    • Use the tip of the blue plastic opening tool to gently flip-up the grey locking flap of the three ribbon cables on the bottom right corner of the motherboard.
    • Grab each ribbon cable and gently pull away from the socket.
    • Move the ribbon cables away from the motherboard.
  9. HP Pavilion 15-p046nr RAM Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 9 단계, 이미지 2개 중 2개
    • To disconnect the speakers, carefully pull on the cables that connect to the motherboard from the speaker system.
    • Be careful not to yank or jerk the cables because they can be easily broken.
    • Move the speaker cables away from the motherboard.
  10. HP Pavilion 15-p046nr RAM Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 10 단계, 이미지 2개 중 2개
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the grey locking flap of the webcam ribbon cable.
    • Grab the ribbon cable cable and gently pull away from the socket.
  11. HP Pavilion 15-p046nr RAM Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement: 11 단계, 이미지 3개 중 3개
    • Unscrew one 6 mm screw on the wireless card with the Phillips #00 screwdriver.
    • The wireless card will angle upwards when the screw is removed.
    • Gently pull the wireless card away from the motherboard with the same angle that it rests.
  12. HP Pavilion 15-p046nr RAM Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement: 12 단계, 이미지 3개 중 3개
    • In the upper left corner of the motherboard, unscrew one captive screw from the charger port cover with the Phillips #00 screwdriver.
    • "Captive screws" are those which will cannot be removed, but will instead remain within their screw hole after being disengaged.
    • Remove the charger port cover.
    • Carefully pull upwards on the charger port to disconnect it.
    • The charger port will stay attached to the device.
  13. HP Pavilion 15-p046nr RAM Replacement: 13 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 13 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the four 6 mm screws from the motherboard using the Phillips #00 screwdriver.
    • Gently lift the motherboard directly up from the holding slots and remove the motherboard from the device.
    • Be careful not to put too much pressure on the motherboard while lifting it up, as there are many fragile circuits and chips on it.
    • Remove the motherboard from the device once it's clear of all cables and slots.
    • Be sure that all cables are clear before reinstalling the motherboard as to not catch any cables beneath.
  14. HP Pavilion 15-p046nr RAM Replacement, RAM: 14 단계, 이미지 3개 중 1개 HP Pavilion 15-p046nr RAM Replacement, RAM: 14 단계, 이미지 3개 중 2개 HP Pavilion 15-p046nr RAM Replacement, RAM: 14 단계, 이미지 3개 중 3개
    • Flip the motherboard over to reveal the RAM card in the bottom right corner.
    • Gently pull both silver locking tabs simultaneously away from eachother.
    • The RAM card will pop up once both tabs are pulled
    • When installing the RAM, there will be a popping noise when it clicks into place.
  15. HP Pavilion 15-p046nr RAM Replacement: 15 단계, 이미지 2개 중 1개 HP Pavilion 15-p046nr RAM Replacement: 15 단계, 이미지 2개 중 2개
    • Grab the RAM card and gently pull it out from the motherboard maintaining the angle at which it rests.
    • Remove the RAM card from the device.
결론
작성자
3다른 기여자 명과 함께
Betsabe Hernandez
회원 가입일: 09/18/19
835 평판
안내서 8개를 작성함
댓글 한 개
Good job. May I suggest that you can even add gifs to your guides.
Henry Opia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 734
