주요 콘텐츠로 건너뛰기
HP Pavilion 15-p066us Battery Replacement
필요한 것
  1. HP Pavilion 15-p066us Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your personal HP Pavilion is powered off and the charger is disconnected from the laptop.
  2. HP Pavilion 15-p066us Battery Replacement: 2 단계, 이미지 1/1
    • Flip over your HP Pavilion to the backside, so you see the battery release and battery unlock slide mechanisms.
  3. HP Pavilion 15-p066us Battery Replacement: 3 단계, 이미지 1/2 HP Pavilion 15-p066us Battery Replacement: 3 단계, 이미지 2/2
    • On the left side on the back of the laptop, you will put your thumb on the unlock slide mechanism and slide it to the right.
  4. HP Pavilion 15-p066us Battery Replacement: 4 단계, 이미지 1/3 HP Pavilion 15-p066us Battery Replacement: 4 단계, 이미지 2/3 HP Pavilion 15-p066us Battery Replacement: 4 단계, 이미지 3/3
    • On the right side of the laptop you will see the slide release mechanism and slide it to the left, then the battery will pop out.
  5. HP Pavilion 15-p066us Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
결론
Tommy
회원 가입일: 08/28/18
393 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G1, Arle Fall 2018 IUPUI, Team S1-G1, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 156
