주요 콘텐츠로 건너뛰기
HP Pavilion 15-p066us Keyboard Replacement
필요한 것
  1. HP Pavilion 15-p066us Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your personal HP Pavilion is powered off and the charger is disconnected from the laptop.
  2. HP Pavilion 15-p066us Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip over your HP Pavilion to the backside, so you see the battery release and battery unlock slide mechanisms.
  3. HP Pavilion 15-p066us Keyboard Replacement: 3 단계, 이미지 1/2 HP Pavilion 15-p066us Keyboard Replacement: 3 단계, 이미지 2/2
    • On the left side on the back of the laptop, you will put your thumb on the unlock slide mechanism and slide it to the right.
  4. HP Pavilion 15-p066us Keyboard Replacement: 4 단계, 이미지 1/3 HP Pavilion 15-p066us Keyboard Replacement: 4 단계, 이미지 2/3 HP Pavilion 15-p066us Keyboard Replacement: 4 단계, 이미지 3/3
    • On the right side of the laptop you will see the slide release mechanism and slide it to the left, then the battery will pop out.
  5. HP Pavilion 15-p066us Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
  6. HP Pavilion 15-p066us Keyboard Replacement, Keyboard: 6 단계, 이미지 1/2 HP Pavilion 15-p066us Keyboard Replacement, Keyboard: 6 단계, 이미지 2/2
    • Remove the twelve 6.4mm #JIS 0 screws from the back of the laptop.
  7. HP Pavilion 15-p066us Keyboard Replacement: 7 단계, 이미지 1/3 HP Pavilion 15-p066us Keyboard Replacement: 7 단계, 이미지 2/3 HP Pavilion 15-p066us Keyboard Replacement: 7 단계, 이미지 3/3
    • Remove the bottom bumper pads and use tweezers to lift and remove the pad.
    • Remove the 7.9mm JIS #0 screw.
  8. HP Pavilion 15-p066us Keyboard Replacement: 8 단계, 이미지 1/2 HP Pavilion 15-p066us Keyboard Replacement: 8 단계, 이미지 2/2
    • Use the plastic opening tool to remove the black casing on both sides of the laptop.
    • Remove the four 6.4mm JIS #0 screws.
  9. HP Pavilion 15-p066us Keyboard Replacement: 9 단계, 이미지 1/3 HP Pavilion 15-p066us Keyboard Replacement: 9 단계, 이미지 2/3 HP Pavilion 15-p066us Keyboard Replacement: 9 단계, 이미지 3/3
    • Remove the CD player on the left side of the laptop.
    • Gently pull the CD player out to access the screws that need to be removed.
    • Remove the three 1.6mm JIS #000 screws under the CD player.
  10. HP Pavilion 15-p066us Keyboard Replacement: 10 단계, 이미지 1/2 HP Pavilion 15-p066us Keyboard Replacement: 10 단계, 이미지 2/2
    • Open the laptop so you can see the laptop keyboard.
    • Use the plastic opening tools to remove the plastic casing as shown.
  11. HP Pavilion 15-p066us Keyboard Replacement: 11 단계, 이미지 1/2 HP Pavilion 15-p066us Keyboard Replacement: 11 단계, 이미지 2/2
    • Using the plastic tool gently raise up the plastic connectors that connect the ZIF connectors.
    • The keyboard should come out as shown.
  12. HP Pavilion 15-p066us Keyboard Replacement: 12 단계, 이미지 1/3 HP Pavilion 15-p066us Keyboard Replacement: 12 단계, 이미지 2/3 HP Pavilion 15-p066us Keyboard Replacement: 12 단계, 이미지 3/3
    • Remove the single 1.6mm screw that is connected to the motherboard.
    • Disconnect the ZIF connector with a plastic opening tool.
    • Use the plastic opening tool to then pop the rivets out of the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tommy
회원 가입일: 08/28/18
393 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G1, Arle Fall 2018 IUPUI, Team S1-G1, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 452
