소개
Remove the old screen on your laptop and replace it with a new one with this easy step by step guide.
필요한 것
Make sure your personal HP Pavilion is powered off and the charger is disconnected from the laptop.
Laptop should be open as shown in the photo.
Remove the 1.6mm JIS #000 screws on the bottom on each side of the screen.
Once screws are removed, the screen will come out. Lay it on keyboard area, then there will be a cable attached to the screen that must be removed.
Remove the cable by lifting up the clear tape and gently pulling away from you to remove the cable connector.
The screen should now be completely removable.
