주요 콘텐츠로 건너뛰기
HP Pavilion 15-p214dx Battery Replacement
필요한 것
  1. HP Pavilion 15-p214dx Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-p214dx Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
  2. HP Pavilion 15-p214dx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-p214dx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release latch (the upper right-hand switch on the laptop's bottom) to the left.
    • While holding the latch in place, remove the battery from the laptop's battery bay.
    • When inserting a battery into the battery bay, the battery release latch does not need to be held open.
결론
To reassemble your device, follow these instructions in reverse order. Opening the battery release latch is not required to plug the battery back in.
작성자
4다른 기여자 명과 함께
Patrick Seaver
회원 가입일: 03/25/19
1,001 평판
안내서 8개를 작성함
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 UMass Dartmouth, Team S2-G1, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G1
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 21
전체 시간: 666
