주요 콘텐츠로 건너뛰기
HP Pavilion 15-p214dx Disk Drive Replacement
필요한 것
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 1/3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 2/3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: 1 단계, 이미지 3/3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-p214dx Disk Drive Replacement: 2 단계, 이미지 2/2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
결론
Patrick Seaver
회원 가입일: 03/25/19
1,001 평판
안내서 8개 작성하였습니다
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 UMass Dartmouth, Team S2-G1, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 252
