주요 콘텐츠로 건너뛰기
HP Pavilion 15-p214dx Top Cover Replacement
필요한 것
  1. HP Pavilion 15-p214dx Top Cover Replacement, Disk Drive: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement, Disk Drive: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-p214dx Top Cover Replacement, Disk Drive: 1 단계, 이미지 3개 중 3개
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Top Cover Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
  3. HP Pavilion 15-p214dx Top Cover Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
  4. HP Pavilion 15-p214dx Top Cover Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 5.5mm screws holding the computer's end caps in place. The end caps are located to the left and right of the battery.
    • These screws are normally hidden underneath the end caps' rubber feet, which are not shown in the pictures. To remove these, gently pry them out of their slots with a plastic opening tool or a flathead screwdriver.
  5. HP Pavilion 15-p214dx Top Cover Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-p214dx Top Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Lift both end caps from their respective corners.
    • Use a Philips #0 screwdriver to remove the 4.3mm screw that is underneath both end caps.
  6. HP Pavilion 15-p214dx Top Cover Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-p214dx Top Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Philips #0 screwdriver to remove the three 5.5mm screws in on the edge of the disk drive slot.
    • These three screws are missing from the pictures.
  7. HP Pavilion 15-p214dx Top Cover Replacement: 7 단계, 이미지 1개 중 1개
    • Flip your computer so that the bottom is now on the surface. Open the laptop like you normally would if you were about to use it.
    • Use a plastic opening tool to separate the top cover from the bottom cover.
    • Be careful when prying the cover off since it is susceptible to bending and cracking.
    • There are several cables connecting the top cover to the computer's motherboard that need to be disconnected before the cover can be completely removed.
  8. HP Pavilion 15-p214dx Top Cover Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement: 8 단계, 이미지 2개 중 2개
    • While lifting the top cover, undo the clip holding the keyboard cable in place.
    • Slide the cable out of its port.
  9. HP Pavilion 15-p214dx Top Cover Replacement: 9 단계, 이미지 1개 중 1개
    • Undo the clip holding the touchpad cable in place.
    • Remove the touchpad cable from its port.
  10. HP Pavilion 15-p214dx Top Cover Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion 15-p214dx Top Cover Replacement: 10 단계, 이미지 2개 중 2개
    • Undo the clip holding the power button cable in place.
    • Disconnect the power button cable from its port.
    • Gently lift the top cover to remove it from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Patrick Seaver
회원 가입일: 03/25/19
1,001 평판
안내서 8개를 작성함
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 UMass Dartmouth, Team S2-G1, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G1
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 948
