주요 콘텐츠로 건너뛰기
HP Pavilion 17 TS Disk Drive Replacement
필요한 것
  1. HP Pavilion 17 TS Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 17 TS Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 17 TS Disk Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: 2 단계, 이미지 3개 중 1개 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: 2 단계, 이미지 3개 중 2개 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: 2 단계, 이미지 3개 중 3개
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 1개 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 2개 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: 3 단계, 이미지 3개 중 3개
    • With the battery compartment closest to you, there will be a 9mm screw next in the center-right of the back plate, labeled with a keyboard symbol and a disk symbol. Remove this phillips screw.
    • In the opening next to the screw, gently push out against the disk drive, and remove it from the disk drive compartment.
결론
작성자
2다른 기여자 명과 함께
Eric Sowersby
회원 가입일: 03/25/16
413 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 회원
UMASSD-MILES-S16S1G6
3 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 549
