주요 콘텐츠로 건너뛰기
HP Pavilion 17 TS Wireless Card Replacement
필요한 것
  1. HP Pavilion 17 TS Wireless Card Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 17 TS Wireless Card Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 17 TS Wireless Card Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: 2 단계, 이미지 3개 중 1개 HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: 2 단계, 이미지 3개 중 2개 HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: 2 단계, 이미지 3개 중 3개
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 1개 HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 2개 HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Undo the two clips attached to the wifi chip by pulling up gently with a pair of tweezers.
    • Unscrew the 9mm phillips screw holding the wifi chip in place.
    • Gently remove the wifi chip from its socket and place it to the side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sean Croft
회원 가입일: 03/25/16
739 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 회원
UMASSD-MILES-S16S1G6
3 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 303
