주요 콘텐츠로 건너뛰기
HP Pavilion 17-e117dx Hard Drive Replacement
필요한 것
  1. HP Pavilion 17-e117dx Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: 3 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3개 중 1개 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3개 중 2개 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3개 중 3개
    • Remove the two Phillips 2.5 x 5.75 mm screws that hold the hard drive down to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 17-e117dx Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 17-e117dx Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the hard drive connector cable from the computer's system board.
  8. HP Pavilion 17-e117dx Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the hard drive out of the hard drive bay by lifting up from the tab.
    • Remove the hard drive from the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Marcel Amazan
회원 가입일: 03/24/19
576 평판
안내서 5개를 작성함
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 UMass Dartmouth, Team S8-G5, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G5
2 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 1,904
