주요 콘텐츠로 건너뛰기
HP Pavilion 17-e117dx WLAN Module Replacement
필요한 것
  1. HP Pavilion 17-e117dx WLAN Module Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx WLAN Module Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx WLAN Module Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: 3 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx WLAN Module Replacement, Service Panel: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx WLAN Module Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx WLAN Module Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the service panel.
  6. HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: 6 단계, 이미지 3개 중 1개 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: 6 단계, 이미지 3개 중 2개 HP Pavilion 17-e117dx WLAN Module Replacement, WLAN Module: 6 단계, 이미지 3개 중 3개
    • Remove the two antenna cables from the top of the WLAN module by pulling them upwards.
    • Be gentle when removing the cables. You don't want to damage them.
  7. HP Pavilion 17-e117dx WLAN Module Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 17-e117dx WLAN Module Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the single Phillips PM 2.5 x 3.25 screw so that you can remove the WLAN module from the system board.
    • Use the Phillips #00 screwdriver.
  8. HP Pavilion 17-e117dx WLAN Module Replacement: 8 단계, 이미지 1개 중 1개
    • To remove the WLAN module, pull it away from the slot at an angle.
결론
작성자
1다른 기여자 명과 함께
Marcel Amazan
회원 가입일: 03/24/19
576 평판
안내서 5개를 작성함
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 UMass Dartmouth, Team S8-G5, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G5
2 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 458
