주요 콘텐츠로 건너뛰기
HP Pavilion 17-f004dx Screen Replacement
필요한 것
  1. HP Pavilion 17-f004dx Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Screen Replacement, CD Drive: 3 단계, 이미지 1개 중 1개
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Screen Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 17-f004dx Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Screen Replacement, Front Panel: 5 단계, 이미지 1개 중 1개
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Screen Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Screen Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Screen Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Screen Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Screen Replacement: 15 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Screen Replacement: 16 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Screen Replacement, Screen: 17 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement, Screen: 17 단계, 이미지 2개 중 2개
    • There is a metal component connecting the screen to the casing underneath each hinge.
    • Remove three 5.6 mm screws with a Phillips 1 screwdriver on each side.
  18. HP Pavilion 17-f004dx Screen Replacement: 18 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 18 단계, 이미지 2개 중 2개
    • Lift the black retaining flap to remove the black cable connecting the screen to the motherboard.
  19. HP Pavilion 17-f004dx Screen Replacement: 19 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 19 단계, 이미지 2개 중 2개
    • Gently remove the black ribbon that was connected to the black flap.
  20. HP Pavilion 17-f004dx Screen Replacement: 20 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 20 단계, 이미지 2개 중 2개
    • Locate the thin black wire that trails from the screen and remove it from the motherboard.
  21. HP Pavilion 17-f004dx Screen Replacement: 21 단계, 이미지 1개 중 1개
    • Remove two small rubber covers on the bottom right and left edges of the screen enclosure using a metal spudger to expose two screws.
  22. HP Pavilion 17-f004dx Screen Replacement: 22 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 22 단계, 이미지 2개 중 2개
    • Remove one 5.6mm screw with a Phillips 1 screwdriver from each side of the bottom screen.
  23. HP Pavilion 17-f004dx Screen Replacement: 23 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 23 단계, 이미지 2개 중 2개
    • Use a metal spudger to remove the plastic casing from the perimeter of the screen.
  24. HP Pavilion 17-f004dx Screen Replacement: 24 단계, 이미지 3개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 24 단계, 이미지 3개 중 2개 HP Pavilion 17-f004dx Screen Replacement: 24 단계, 이미지 3개 중 3개
    • Be careful not to damage the wires.
    • Use a metal spudger to partially remove the screen from the plastic case.
  25. HP Pavilion 17-f004dx Screen Replacement: 25 단계, 이미지 2개 중 1개 HP Pavilion 17-f004dx Screen Replacement: 25 단계, 이미지 2개 중 2개
    • Do not touch the circuit board directly.
    • Flip the screen over and remove the tape that holds down the ribbon.
  26. HP Pavilion 17-f004dx Screen Replacement: 26 단계, 이미지 1개 중 1개
    • Pull the ribbon away from the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chi Huynh
회원 가입일: 09/21/16
726 평판
안내서 2개를 작성함
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 7
전체 시간: 2,700
