주요 콘텐츠로 건너뛰기
HP Pavilion 17-f127ds Optical Drive Replacement
필요한 것
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: 2 단계, 이미지 1/2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: 3 단계, 이미지 1/1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
결론
Stephen Brown
회원 가입일: 10/18/17
201 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017 회원
UWT-LINER-F17S3G1
5 회원들
안내서 4개 작성하였습니다
댓글 한 개
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 906
