주요 콘텐츠로 건너뛰기
HP Pavilion 17-f127ds Speakers Replacement
필요한 것
  1. HP Pavilion 17-f127ds Speakers Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion 17-f127ds Speakers Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion 17-f127ds Speakers Replacement, Battery: 1 단계, 이미지 3/3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: 2 단계, 이미지 1/2 HP Pavilion 17-f127ds Speakers Replacement, Keyboard: 2 단계, 이미지 2/2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Speakers Replacement: 3 단계, 이미지 1/3 HP Pavilion 17-f127ds Speakers Replacement: 3 단계, 이미지 2/3 HP Pavilion 17-f127ds Speakers Replacement: 3 단계, 이미지 3/3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
  4. HP Pavilion 17-f127ds Speakers Replacement, Speakers: 4 단계, 이미지 1/2 HP Pavilion 17-f127ds Speakers Replacement, Speakers: 4 단계, 이미지 2/2
    • Disconnect the tape connecting the WLAN module to the main board.
    • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  5. HP Pavilion 17-f127ds Speakers Replacement: 5 단계, 이미지 1/2 HP Pavilion 17-f127ds Speakers Replacement: 5 단계, 이미지 2/2
    • Disconnect the speakers from the main board.
    • Lift away the speakers, they are connected with a wire.
결론
Stephen Brown
회원 가입일: 10/18/17
201 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017 회원
UWT-LINER-F17S3G1
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 357
