주요 콘텐츠로 건너뛰기
HP Pavilion 17-g119dx RAM Replacement
필요한 것
  1. HP Pavilion 17-g119dx RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion 17-g119dx RAM Replacement: 2 단계, 이미지 2/2
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx RAM Replacement: 3 단계, 이미지 1/2 HP Pavilion 17-g119dx RAM Replacement: 3 단계, 이미지 2/2
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx RAM Replacement: 4 단계, 이미지 1/2 HP Pavilion 17-g119dx RAM Replacement: 4 단계, 이미지 2/2
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx RAM Replacement, RAM: 5 단계, 이미지 1/3 HP Pavilion 17-g119dx RAM Replacement, RAM: 5 단계, 이미지 2/3 HP Pavilion 17-g119dx RAM Replacement, RAM: 5 단계, 이미지 3/3
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx RAM Replacement: 6 단계, 이미지 1/3 HP Pavilion 17-g119dx RAM Replacement: 6 단계, 이미지 2/3 HP Pavilion 17-g119dx RAM Replacement: 6 단계, 이미지 3/3
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx RAM Replacement: 7 단계, 이미지 1/3 HP Pavilion 17-g119dx RAM Replacement: 7 단계, 이미지 2/3 HP Pavilion 17-g119dx RAM Replacement: 7 단계, 이미지 3/3
    • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx RAM Replacement: 8 단계, 이미지 1/3 HP Pavilion 17-g119dx RAM Replacement: 8 단계, 이미지 2/3 HP Pavilion 17-g119dx RAM Replacement: 8 단계, 이미지 3/3
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
  9. HP Pavilion 17-g119dx RAM Replacement: 9 단계, 이미지 1/3 HP Pavilion 17-g119dx RAM Replacement: 9 단계, 이미지 2/3 HP Pavilion 17-g119dx RAM Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
  10. HP Pavilion 17-g119dx RAM Replacement: 10 단계, 이미지 1/2 HP Pavilion 17-g119dx RAM Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • After running the Plastic Opening Tool along the sides, you can gently lift the keyboard up and on top of the screen to access the RAM.
    • The RAM will be located above the Motherboard and next to the Processor.
  11. HP Pavilion 17-g119dx RAM Replacement: 11 단계, 이미지 1/2 HP Pavilion 17-g119dx RAM Replacement: 11 단계, 이미지 2/2
    • Release the RAM by pulling the two white levers away from the sides of the RAM.
  12. HP Pavilion 17-g119dx RAM Replacement: 12 단계, 이미지 1/1
    • Pull the RAM up and out of the laptop to remove it.
    • When reassembling, be sure to insert the RAM at the same angle it came out. Then push it down into place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Morgan Best
회원 가입일: 10/30/17
403 평판
안내서 2개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 28
전체 시간: 2,550
