주요 콘텐츠로 건너뛰기
HP Pavilion 17-g192dx Screen Replacement
필요한 것
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion 17-g192dx Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion 17-g192dx Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 17-g192dx Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 HP Pavilion 17-g192dx Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
  5. HP Pavilion 17-g192dx Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 7mm screws with a Philips #00 screwdriver.
  6. HP Pavilion 17-g192dx Screen Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 17-g192dx Screen Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 17-g192dx Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
  7. HP Pavilion 17-g192dx Screen Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 17-g192dx Screen Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 17-g192dx Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
  8. HP Pavilion 17-g192dx Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
  9. HP Pavilion 17-g192dx Screen Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion 17-g192dx Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dominic Perito
회원 가입일: 09/20/19
616 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 384
