주요 콘텐츠로 건너뛰기
HP Pavilion DM3-3010US Hard Drive Replacement
필요한 것
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion DM3-3010US Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion DM3-3010US Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Somesh Rai
회원 가입일: 01/30/15
147 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 1,920
