주요 콘텐츠로 건너뛰기
HP Pavilion DM3-3010US Sound Card Replacement
필요한 것
  1. HP Pavilion DM3-3010US Sound Card Replacement, Sound Card: 1 단계, 이미지 1개 중 1개
    • Place the laptop upside down on a stable surface and locate the battery ejection switch.
  2. HP Pavilion DM3-3010US Sound Card Replacement: 2 단계, 이미지 1개 중 1개
    • Eject the battery by sliding the switch sideways.
  3. HP Pavilion DM3-3010US Sound Card Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery outwards.
  4. HP Pavilion DM3-3010US Sound Card Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 2 plastic panels covering the internals of the laptop.
    • The rectangular panel can be removed by sliding the latch.
    • The square panel is removable once the battery is removed.
  5. HP Pavilion DM3-3010US Sound Card Replacement: 5 단계, 이미지 1개 중 1개
    • Removing the square panel reveals the location of the hard drive.
  6. HP Pavilion DM3-3010US Sound Card Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the two screws located on the side of the hard drive mounting hardware.
    • This is accessible from the back of the laptop, where the battery was located.
  7. HP Pavilion DM3-3010US Sound Card Replacement: 7 단계, 이미지 1개 중 1개
    • Locate the 4 additional screws on the top of the mounting hardware for the hard drive.
    • Remove and set aside these screws.
  8. HP Pavilion DM3-3010US Sound Card Replacement: 8 단계, 이미지 1개 중 1개
    • Pay attention to the SATA cable connecting the hard drive to the motherboard. It can be damaged if handled roughly.
    • Pull the SATA cable out of its receptacle and set the hard drive aside.
  9. HP Pavilion DM3-3010US Sound Card Replacement: 9 단계, 이미지 1개 중 1개
    • The picture shows the HP Pavilion DM3-3000 Series Audio USB Card Reader Board w/Cable.
    • With the hard drive removed, open the laptop and set it down in the position for normal use.
    • Locate the seam between the top panel of the laptop and the frame.
    • The seam is on the left side of the laptop when the screen is facing you.
    • Pull the top cover, including keyboard, up from the left side of the laptop.
  10. HP Pavilion DM3-3010US Sound Card Replacement: 10 단계, 이미지 1개 중 1개
    • Dismount the audio driver by removing the 4 highlighted screws.
    • The audio driver is located on the right side of the laptop while the screen is facing you.
  11. HP Pavilion DM3-3010US Sound Card Replacement: 11 단계, 이미지 1개 중 1개
    • The audio driver and surrounding components are susceptible to damage if handled incorrectly.
    • Carefully pull the audio driver upwards, away from the motherboard.
    • The laptop is now ready to receive the replacement audio driver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
michael mannen
회원 가입일: 01/30/15
446 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,783
