주요 콘텐츠로 건너뛰기
HP Pavilion DM4 Hard Drive Replacement
필요한 것
  1. HP Pavilion DM4 Hard Drive  Replacement, Hard drive: 1 단계, 이미지 1/2 HP Pavilion DM4 Hard Drive  Replacement, Hard drive: 1 단계, 이미지 2/2
    • Unlock and remove the battery pack.
  2. HP Pavilion DM4 Hard Drive  Replacement: 2 단계, 이미지 1/3 HP Pavilion DM4 Hard Drive  Replacement: 2 단계, 이미지 2/3 HP Pavilion DM4 Hard Drive  Replacement: 2 단계, 이미지 3/3
    • Unscrew the hidden screws covered by the battery pack and remove the panel to find more hidden screws.
  3. HP Pavilion DM4 Hard Drive  Replacement: 3 단계, 이미지 1/3 HP Pavilion DM4 Hard Drive  Replacement: 3 단계, 이미지 2/3 HP Pavilion DM4 Hard Drive  Replacement: 3 단계, 이미지 3/3
    • Unscrew the hidden screws in order to remove the hard drive cover.
  4. HP Pavilion DM4 Hard Drive  Replacement: 4 단계, 이미지 1/1
    • Pull out the tab to remove the hard drive.
  5. HP Pavilion DM4 Hard Drive  Replacement: 5 단계, 이미지 1/3 HP Pavilion DM4 Hard Drive  Replacement: 5 단계, 이미지 2/3 HP Pavilion DM4 Hard Drive  Replacement: 5 단계, 이미지 3/3
    • Take the hard drive out and pull the connector from it.
    • In order to disconnect the hard drive, grab the hard drive and cord then gently pull the hard drive away from the cord.
  6. HP Pavilion DM4 Hard Drive  Replacement: 6 단계, 이미지 1/1
    • Replace the hard drive.
    • Do not take apart the hard drive if you want it to run anything at all!
결론
다른 8명이 해당 안내서를 완성하였습니다.
Wyatt Marsalek
회원 가입일: 06/01/16
173 평판
안내서 1개 작성함
댓글 한 개
I need to replace the hard drive and was wondering how large can the DM4 handle. It is currently 578Gb and it would be great for 1 or 2 TB. Thanks
epascual1960 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 35
전체 시간: 7,960
