주요 콘텐츠로 건너뛰기
HP Pavilion DM4 Hard Drive Replacement
필요한 것
  1. HP Pavilion DM4 Hard Drive  Replacement, Hard drive: 1 단계, 이미지 2개 중 1개 HP Pavilion DM4 Hard Drive  Replacement, Hard drive: 1 단계, 이미지 2개 중 2개
    • Unlock and remove the battery pack.
  2. HP Pavilion DM4 Hard Drive  Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion DM4 Hard Drive  Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion DM4 Hard Drive  Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the hidden screws covered by the battery pack and remove the panel to find more hidden screws.
  3. HP Pavilion DM4 Hard Drive  Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion DM4 Hard Drive  Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion DM4 Hard Drive  Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the hidden screws in order to remove the hard drive cover.
    Screws were not removable on my machine. So, I would replace the word “remove” with “loosen” to avoid chance for cross-threading. otherwise, these directions were EXCELLENT.
    Vincent Juliano - 답글
  4. HP Pavilion DM4 Hard Drive  Replacement: 4 단계, 이미지 1개 중 1개
    • Pull out the tab to remove the hard drive.
  5. HP Pavilion DM4 Hard Drive  Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion DM4 Hard Drive  Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion DM4 Hard Drive  Replacement: 5 단계, 이미지 3개 중 3개
    • Take the hard drive out and pull the connector from it.
    • In order to disconnect the hard drive, grab the hard drive and cord then gently pull the hard drive away from the cord.
  6. HP Pavilion DM4 Hard Drive  Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the hard drive.
    • Do not take apart the hard drive if you want it to run anything at all!
    thanks that was helpful
    Mhamad MC - 답글
    One more thing here is that you have to remove four screws that attach the little metal/plastic sleeve to the actual drive, and then slide the old drive out of the sleeve and the new one back in. Thanks for the guide.
    Evan - 답글
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Wyatt Marsalek
회원 가입일: 06/01/16
173 평판
안내서 1개를 작성함
댓글 한 개
I need to replace the hard drive and was wondering how large can the DM4 handle. It is currently 578Gb and it would be great for 1 or 2 TB. Thanks
epascual1960 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 29
전체 시간: 8,181
