주요 콘텐츠로 건너뛰기
HP Pavilion DV1000 Screen Replacement
필요한 것
  1. HP Pavilion DV1000 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion DV1000 Screen Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over.
  3. HP Pavilion DV1000 Screen Replacement: 3 단계, 이미지 1/2 HP Pavilion DV1000 Screen Replacement: 3 단계, 이미지 2/2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion DV1000 Screen Replacement: 4 단계, 이미지 1/3 HP Pavilion DV1000 Screen Replacement: 4 단계, 이미지 2/3 HP Pavilion DV1000 Screen Replacement: 4 단계, 이미지 3/3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion DV1000 Screen Replacement, Keyboard: 5 단계, 이미지 1/1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion DV1000 Screen Replacement: 6 단계, 이미지 1/2 HP Pavilion DV1000 Screen Replacement: 6 단계, 이미지 2/2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion DV1000 Screen Replacement, Media Keys: 7 단계, 이미지 1/1
    • Turn the laptop upside-down again.
  8. HP Pavilion DV1000 Screen Replacement: 8 단계, 이미지 1/2 HP Pavilion DV1000 Screen Replacement: 8 단계, 이미지 2/2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
  9. HP Pavilion DV1000 Screen Replacement, Screen: 9 단계, 이미지 1/1
    • Remove the rubber inserts with the spudger.
    • Note: When reassembling, notice that the two lower rubber pieces are flatter than the four rubber pieces located at the top of the screen.
    • Remove the screws behind the rubber inserts.
  10. HP Pavilion DV1000 Screen Replacement: 10 단계, 이미지 1/2 HP Pavilion DV1000 Screen Replacement: 10 단계, 이미지 2/2
    • Carefully pry loose the screen casing with a plastic prying tool.
  11. HP Pavilion DV1000 Screen Replacement: 11 단계, 이미지 1/2 HP Pavilion DV1000 Screen Replacement: 11 단계, 이미지 2/2
    • Remove the plug by prying it loose with the spudger.
    • Pulling the plug with your fingers could be potentially dangerous unless you are wearing work gloves.
  12. HP Pavilion DV1000 Screen Replacement: 12 단계, 이미지 1/1
    • Remove the single screw marked in the image.
    • Be careful not to break the clips or pull any wires.
  13. HP Pavilion DV1000 Screen Replacement: 13 단계, 이미지 1/3 HP Pavilion DV1000 Screen Replacement: 13 단계, 이미지 2/3 HP Pavilion DV1000 Screen Replacement: 13 단계, 이미지 3/3
    • Remove the 4 screws marked in the picture.
    • Support the back cover and set it down on the desk. Do not pull off the back cover.
  14. HP Pavilion DV1000 Screen Replacement: 14 단계, 이미지 1/2 HP Pavilion DV1000 Screen Replacement: 14 단계, 이미지 2/2
    • Remove the screws on each side of the screen. There are four screws on each side.
    • Remove the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler Latour
회원 가입일: 03/12/14
266 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S6G7
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 3,364
