주요 콘텐츠로 건너뛰기
HP Pavilion DV2160BR Battery Replacement
  1. HP Pavilion DV2160BR Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Battery Replacement: 2 단계, 이미지 1/2 HP Pavilion DV2160BR Battery Replacement: 2 단계, 이미지 2/2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
결론
Shannon
회원 가입일: 04/11/13
55 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G66
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 301
