주요 콘텐츠로 건너뛰기
HP Pavilion DV2160BR DVD±RW Drive Replacement
필요한 것
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: 2 단계, 이미지 1/2 HP Pavilion DV2160BR DVD±RW Drive Replacement: 2 단계, 이미지 2/2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: 3 단계, 이미지 1/1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: 4 단계, 이미지 1/2 HP Pavilion DV2160BR DVD±RW Drive Replacement: 4 단계, 이미지 2/2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: 5 단계, 이미지 1/1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: 6 단계, 이미지 1/1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon MacDonald
회원 가입일: 03/12/14
239 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S6G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 231
