소개
In this guide you will learn how to remove the DVD±RW Drive from an HP Pavilion DV2160BR.
  1. Start with the bottom of the laptop facing up.
    • Start with the bottom of the laptop facing up.
  2. Locate the battery compartment at the rear of the device. There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Locate the  locking screw which is located in a recessed hole on the underside of the laptop.
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  5. Locate the CD drive tray release hole on the front of the drive. Straighten a paper clip and push it gently into the CD drive tray release hole.
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  6. Grasp the side edges of the drive tray.
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  7. Locate the mounting bracket which is attached to the back of  the drive.
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon MacDonald
회원 가입일: 2014년 03월 12일
239 평판
안내서 2개 작성하였습니다
University of Maryland, Team 6-5, Vijaybhaskar Spring 2014 University of Maryland, Team 6-5, Vijaybhaskar Spring 2014 회원
UMD-VIJAYBHASKAR-S14S6G5
3 회원들
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 157
