이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the battery compartment at the rear of the device.
There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
Locate the locking screw which is located in a recessed hole on the underside of the laptop.
Remove the M2.5X3-Lg #1 Phillips screw.
Locate the CD drive tray release hole on the front of the drive.
Straighten a paper clip and push it gently into the CD drive tray release hole.
The drive tray will pop open.
Grasp the side edges of the drive tray.
Gently pull the drive from the laptop.
Locate the mounting bracket which is attached to the back of the drive.
Remove the two M2x3-Lg #0 Phillips screws.
다른 한 분이 해당 안내서를 완성하였습니다.
