주요 콘텐츠로 건너뛰기
HP Pavilion DV2160BR Hard Drive Replacement
필요한 것
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: 2 단계, 이미지 1/1
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion DV2160BR Hard Drive Replacement: 3 단계, 이미지 2/2
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: 4 단계, 이미지 1/1
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: 5 단계, 이미지 1/3 HP Pavilion DV2160BR Hard Drive Replacement: 5 단계, 이미지 2/3 HP Pavilion DV2160BR Hard Drive Replacement: 5 단계, 이미지 3/3
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shannon
회원 가입일: 04/11/13
55 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G66
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 535
