주요 콘텐츠로 건너뛰기
HP Pavilion DV2160BR Inverter Replacement
필요한 것
  1. HP Pavilion DV2160BR Inverter Replacement, Inverter: 1 단계, 이미지 1/1
    • Start with the laptop sitting up and open.
  2. HP Pavilion DV2160BR Inverter Replacement: 2 단계, 이미지 1/3 HP Pavilion DV2160BR Inverter Replacement: 2 단계, 이미지 2/3 HP Pavilion DV2160BR Inverter Replacement: 2 단계, 이미지 3/3
    • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
    • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
    • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
    • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
  3. HP Pavilion DV2160BR Inverter Replacement: 3 단계, 이미지 1/2 HP Pavilion DV2160BR Inverter Replacement: 3 단계, 이미지 2/2
    • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
  4. HP Pavilion DV2160BR Inverter Replacement: 4 단계, 이미지 1/2 HP Pavilion DV2160BR Inverter Replacement: 4 단계, 이미지 2/2
    • The inverter is located underneath the screen.
    • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
  5. HP Pavilion DV2160BR Inverter Replacement: 5 단계, 이미지 1/2 HP Pavilion DV2160BR Inverter Replacement: 5 단계, 이미지 2/2
    • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
    • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
  6. HP Pavilion DV2160BR Inverter Replacement: 6 단계, 이미지 1/1
    • Remove the inverter from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Shannon
회원 가입일: 04/11/13
55 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G66
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 19
전체 시간: 1,404
