소개
If you're having any issues with your keyboard, use this guide to disassemble your laptop and access the keyboard for repair or replacement. This installation requires loosening some screws and carefully using the iFixit plastic opening tools.
필요한 것
Unscrew the 5 screws along the top edge of the laptop’s back panel and inside the battery compartment.
The two screws inside the battery compartment are 5mm Phillips #1.
The three screws outside the battery compartment are 9mm Phillips #1.
거의 끝나갑니다!
결론
