주요 콘텐츠로 건너뛰기
HP Pavilion DV2160BR Webcam Replacement
필요한 것
  1. HP Pavilion DV2160BR Webcam Replacement, Battery: 1 단계, 이미지 1/1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Webcam Replacement: 2 단계, 이미지 1/2 HP Pavilion DV2160BR Webcam Replacement: 2 단계, 이미지 2/2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Webcam Replacement, Webcam: 3 단계, 이미지 1/1
    • Flip over the laptop and open it.
  4. HP Pavilion DV2160BR Webcam Replacement: 4 단계, 이미지 1/2 HP Pavilion DV2160BR Webcam Replacement: 4 단계, 이미지 2/2
    • Remove the 6 rubber screw covers from the screen panel using the plastic opener tools by applying firm pressure to the edges.
    • The 4 screw covers on top are attached by an adhesive backing.
    • The 2 screw covers on the bottom are rubber plugs.
  5. HP Pavilion DV2160BR Webcam Replacement: 5 단계, 이미지 1/1
    • Remove the 4 M2.5x4-Lg #0 Phillips screws from the top of the screen panel.
    • Remove the 2 M2.5x8-Lg #1 Phillips screws from the bottom of the screen panel.
  6. HP Pavilion DV2160BR Webcam Replacement: 6 단계, 이미지 1/2 HP Pavilion DV2160BR Webcam Replacement: 6 단계, 이미지 2/2
    • Slide a plastic opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. HP Pavilion DV2160BR Webcam Replacement: 7 단계, 이미지 1/1
    • Locate the screw on the left side of the cameras mounting bracket.
    • Remove the M2.5x4-Lg #0 Phillips screw
  8. HP Pavilion DV2160BR Webcam Replacement: 8 단계, 이미지 1/1
    • Pull the camera from the back screen panel and rotate it so you are looking at the back.
    • Remove the 2 M2x3-Lg #00 Phillips screws and place the mounting bracket aside.
  9. HP Pavilion DV2160BR Webcam Replacement: 9 단계, 이미지 1/1
    • Disconnect the cable on the right side of the camera board by pulling firmly on the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon MacDonald
회원 가입일: 03/12/14
239 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S6G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 774
