주요 콘텐츠로 건너뛰기
HP Pavilion DV2160BR Wifi Adapter Replacement
필요한 것
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: 1 단계, 이미지 1/2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: 1 단계, 이미지 2/2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: 2 단계, 이미지 1/2 HP Pavilion DV2160BR Wifi Adapter Replacement: 2 단계, 이미지 2/2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: 3 단계, 이미지 1/2 HP Pavilion DV2160BR Wifi Adapter Replacement: 3 단계, 이미지 2/2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shannon
회원 가입일: 04/11/13
55 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G66
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 509
