주요 콘텐츠로 건너뛰기
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
필요한 것
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 2 단계, 이미지 1/2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 2 단계, 이미지 2/2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: 3 단계, 이미지 1/1
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 4 단계, 이미지 1/2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 4 단계, 이미지 2/2
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 5 단계, 이미지 1/3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 5 단계, 이미지 2/3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 5 단계, 이미지 3/3
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 6 단계, 이미지 1/2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 6 단계, 이미지 2/2
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 7 단계, 이미지 1/2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: 7 단계, 이미지 2/2
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Baldovin
회원 가입일: 09/30/13
548 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-10, Forte Fall 2013 Cal Poly, Team 14-10, Forte Fall 2013 회원
CPSU-FORTE-F13S14G10
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 1,649
