소개
This guide will demonstrate how to remove the hard drive from you laptop. You will need the screwdriver listed in the tools section.
필요한 것
Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
다른 5명이 해당 안내서를 완성하였습니다.
