주요 콘텐츠로 건너뛰기
HP Pavilion DV5T-1000 Hard Drive Replacement
필요한 것
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion DV5T-1000 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion DV5T-1000 Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion DV5T-1000 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Josh Taimanglo
회원 가입일: 09/21/15
165 평판
안내서 1개를 작성함
댓글 한 개
Help after replacing hard drive installation of windows
Bettyjean Serrano - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 21
전체 시간: 2,063
