주요 콘텐츠로 건너뛰기
HP Pavilion DV6-6C35DX Hard Drive Replacement
필요한 것
  1. HP Pavilion DV6-6C35DX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 HP Pavilion DV6-6C35DX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • Flip the laptop so the bottom is facing up.
    • Push the sliding latch to the left to release the battery and remove it from the laptop.
  2. HP Pavilion DV6-6C35DX Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Push the same sliding latch to the right to release the L-shaped panel.
    • Remove the panel from the laptop.
    • You may need to use a spudger to pry out the L-shaped panel and release any clips before removing it.
    • When reassembling the device, make sure to start by inserting the bottom of the panel first (see image 3).
  3. HP Pavilion DV6-6C35DX Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws that secure the hard drive.
  4. HP Pavilion DV6-6C35DX Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the hard drive out of the slot from the side under the RAM slot.
    • Be careful not to pull on the cable connecting the hard drive to the laptop.
    • Use a spudger to help lift the drive out of the chassis if you are unable to with your fingers.
  5. HP Pavilion DV6-6C35DX Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the plastic ribbon attached to the connector to disconnect hard drive from the laptop.
  6. HP Pavilion DV6-6C35DX Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws on the side of the hard drive cage.
    • When removing the screws, hold the drive cage carefully to prevent the hard drive from falling out.
    • Remove the hard drive from the cage.
  7. HP Pavilion DV6-6C35DX Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion DV6-6C35DX Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the SATA cable from the hard drive.
결론
작성자
1다른 기여자 명과 함께
Jake M.
회원 가입일: 06/23/24
145 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 9
전체 시간: 196
