주요 콘텐츠로 건너뛰기
HP Pavilion DV9700 Keyboard Replacement
필요한 것
  1. HP Pavilion DV9700 Keyboard  Replacement, Digital Media Control Panel: 1 단계, 이미지 2개 중 1개 HP Pavilion DV9700 Keyboard  Replacement, Digital Media Control Panel: 1 단계, 이미지 2개 중 2개
    • First turn the device so that the back is facing upward.
    • There is a tab located near the top left portion of the device.
    • Push the tab and pull the battery upward to remove the battery from the device.
  2. HP Pavilion DV9700 Keyboard  Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 2 단계, 이미지 2개 중 2개
    • In the battery compartment there are 6 4mm screws.
    • Unscrew these screws using a Philips #0 head screwdriver.
    • These screws are very small, make sure to have an organized place to put them.
  3. HP Pavilion DV9700 Keyboard  Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion DV9700 Keyboard  Replacement: 3 단계, 이미지 3개 중 3개
    • Turn the laptop over to it's resting position.
    • Open the laptop and locate the media bar across the top of the keyboard.
    • On the left side of the media bar, insert a spudger under the media bar near the top.
    • Move the spudger toward the bottom of the media bar, releasing the clips.
  4. HP Pavilion DV9700 Keyboard  Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion DV9700 Keyboard  Replacement: 4 단계, 이미지 3개 중 3개
    • On the right of the media bar insert the spudger near the top.
    • Move the spudger toward the bottom of the media to release the clips
  5. HP Pavilion DV9700 Keyboard  Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully pull the media bar upward about an inch.
    • Flip the media bar toward yourself to expose the cable still attached.
    • Make sure not to pull the media bar too far away from the device. This could cause damage to the cable or the cable port.
  6. HP Pavilion DV9700 Keyboard  Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion DV9700 Keyboard  Replacement: 6 단계, 이미지 3개 중 3개
    • The ribbon cable is located near the left side of the media bar.
    • The ribbon cable is held down by a brown clip.
    • Using a fingernail pry one of the sides of the clip to release it.
    • The clip is fragile, be careful not to use too much pressure.
  7. HP Pavilion DV9700 Keyboard  Replacement: 7 단계, 이미지 1개 중 1개
    • With the ribbon cable successfully detached you may now replace the media bar with a new, functioning one.
  8. HP Pavilion DV9700 Keyboard  Replacement, Keyboard: 8 단계, 이미지 2개 중 1개 HP Pavilion DV9700 Keyboard  Replacement, Keyboard: 8 단계, 이미지 2개 중 2개
    • There are three 4mm screws located above the keyboard.
    • Remove the screws using a Philips #0 screwdriver.
    • These screws are very small, make sure to have an organize place to put them.
  9. HP Pavilion DV9700 Keyboard  Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 9 단계, 이미지 2개 중 2개
    • Grab the top corners of the keyboard and pull upward about an inch.
    • Then pull the keyboard toward the monitor to release it from the casing.
  10. HP Pavilion DV9700 Keyboard  Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion DV9700 Keyboard  Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion DV9700 Keyboard  Replacement: 10 단계, 이미지 3개 중 3개
    • The keyboard will be attached with a ribbon cable from underneath.
    • Carefully pry the black clip that is holding the cable to release.
    • Both the ribbon cable and clip are fragile, make sure not to lift the keyboard so high that the cable can tear.
  11. HP Pavilion DV9700 Keyboard  Replacement: 11 단계, 이미지 1개 중 1개
    • You may now lift the keyboard from the laptop and replace it with a new, functioning one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Max Shangraw
회원 가입일: 03/19/18
507 평판
안내서 4개를 작성함
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 UMass Dartmouth, Team S6-G1, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G1
3 회원들
안내서 4개를 작성함
댓글 한 개
didnt help ahh your advice suck
Luis Perez Cruz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 784
