주요 콘텐츠로 건너뛰기
HP Pavilion DV9700 RAM Replacement
필요한 것
  1. HP Pavilion DV9700 RAM Replacement, RAM: 1 단계, 이미지 1/2 HP Pavilion DV9700 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion DV9700 RAM Replacement: 2 단계, 이미지 2/2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: 3 단계, 이미지 1/3 HP Pavilion DV9700 RAM Replacement: 3 단계, 이미지 2/3 HP Pavilion DV9700 RAM Replacement: 3 단계, 이미지 3/3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: 4 단계, 이미지 1/3 HP Pavilion DV9700 RAM Replacement: 4 단계, 이미지 2/3 HP Pavilion DV9700 RAM Replacement: 4 단계, 이미지 3/3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
결론
Max Shangraw
회원 가입일: 03/19/18
507 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 UMass Dartmouth, Team S6-G1, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 776
