주요 콘텐츠로 건너뛰기
HP Pavilion G6-1d16dx RAM Replacement
필요한 것
  1. HP Pavilion G6-1d16dx RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx RAM Replacement: 2 단계, 이미지 1/1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx RAM Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx RAM Replacement, RAM: 4 단계, 이미지 1/2 HP Pavilion G6-1d16dx RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
    • The screws do not remove from the cover.
    • Unsnap the cover by lifting the edge along the battery compartment.
  5. HP Pavilion G6-1d16dx RAM Replacement: 5 단계, 이미지 1/1
    • Push the two tabs on the sides of the RAM compartment away from the memory stick.
    • This can be done with your fingers, or any sort of flat edged tool.
  6. HP Pavilion G6-1d16dx RAM Replacement: 6 단계, 이미지 1/2 HP Pavilion G6-1d16dx RAM Replacement: 6 단계, 이미지 2/2
    • After the tabs are moved, the RAM stick will pop up, and you can pull the card straight out of its slot.
    • Place the stick (new or original) back into the same slot where you pulled the previous stick from, and press straight down on the card until the tabs click into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Calvin Kerr
회원 가입일: 04/05/18
878 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 2,232
