주요 콘텐츠로 건너뛰기
HP Pavilion G6-1d16dx Screen hinges Replacement
필요한 것
  1. HP Pavilion G6-1d16dx Screen hinges Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Screen hinges Replacement: 2 단계, 이미지 1/1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Screen hinges Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Screen hinges Replacement, Motherboard: 4 단계, 이미지 1/1
    • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
    • The screws do not remove from the cover.
  5. HP Pavilion G6-1d16dx Screen hinges Replacement: 5 단계, 이미지 1/2 HP Pavilion G6-1d16dx Screen hinges Replacement: 5 단계, 이미지 2/2
    • Unsnap the Cover by lifting the edge along the battery compartment.
    • Remove all of the body screws.
    • Remove the rubber cap and the screw underneath it.
  6. HP Pavilion G6-1d16dx Screen hinges Replacement: 6 단계, 이미지 1/3 HP Pavilion G6-1d16dx Screen hinges Replacement: 6 단계, 이미지 2/3 HP Pavilion G6-1d16dx Screen hinges Replacement: 6 단계, 이미지 3/3
    • The keyboard is held in by nine tabs
    • Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
  7. HP Pavilion G6-1d16dx Screen hinges Replacement: 7 단계, 이미지 1/2 HP Pavilion G6-1d16dx Screen hinges Replacement: 7 단계, 이미지 2/2
    • Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
    • As you depress the tabs, the edges of the keyboard will pop up.
    • Lift off the keyboard
  8. HP Pavilion G6-1d16dx Screen hinges Replacement: 8 단계, 이미지 1/1
    • Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
  9. HP Pavilion G6-1d16dx Screen hinges Replacement: 9 단계, 이미지 1/3 HP Pavilion G6-1d16dx Screen hinges Replacement: 9 단계, 이미지 2/3 HP Pavilion G6-1d16dx Screen hinges Replacement: 9 단계, 이미지 3/3
    • Remove the two remaining ribbon cables.
    • Remove the screws holding in the protective cover underneath the keyboard.
    • Pop the cover off using any flat metal tool, starting with where you took out the optical drive
    • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
  10. HP Pavilion G6-1d16dx Screen hinges Replacement: 10 단계, 이미지 1/1
    • Unplug the ribbon cable on the right side of the motherboard.
  11. HP Pavilion G6-1d16dx Screen hinges Replacement: 11 단계, 이미지 1/2 HP Pavilion G6-1d16dx Screen hinges Replacement: 11 단계, 이미지 2/2
    • Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
  12. HP Pavilion G6-1d16dx Screen hinges Replacement: 12 단계, 이미지 1/1
    • Unscrew all mother board screws and lift the motherboard out of the body.
    • For replacing the screen hinges and screen, skip this step
  13. HP Pavilion G6-1d16dx Screen hinges Replacement, Screen hinges: 13 단계, 이미지 1/1
    • Remove the five screws holding hinges to base.
    • Do not unscrew the motherboard screws
  14. HP Pavilion G6-1d16dx Screen hinges Replacement: 14 단계, 이미지 1/2 HP Pavilion G6-1d16dx Screen hinges Replacement: 14 단계, 이미지 2/2
    • Lift the tape tab up from the screen plug, and unplug the screen from the motherboard.
    • Unplug the wires from the wireless card and pull them through the body.
  15. HP Pavilion G6-1d16dx Screen hinges Replacement: 15 단계, 이미지 1/1
    • Remove the sticky tabs on the bottom of the screen just outside the hinges, and remove the two screws underneath.
  16. HP Pavilion G6-1d16dx Screen hinges Replacement: 16 단계, 이미지 1/1
    • Pry off the plastic surrounding the screen with any flat metal tool.
  17. HP Pavilion G6-1d16dx Screen hinges Replacement: 17 단계, 이미지 1/1
    • Remove the screws holding the hinge covers in place.
    • Remove the hinge covers.
  18. HP Pavilion G6-1d16dx Screen hinges Replacement: 18 단계, 이미지 1/1
    • Use a pair of pliers to unscrew the nut and pull out the hinge.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Calvin Kerr
회원 가입일: 04/05/18
878 평판
안내서 5개 작성하였습니다
댓글 한 개
Not so good a manual. See my remarks.
This laptop is of extremely poor building quality. Disaster lures in every badly made detail.
Eveline Bernard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 23
전체 시간: 3,450
