주요 콘텐츠로 건너뛰기
HP Pavilion G6-1d16dx Wireless Card Replacement
필요한 것
  1. HP Pavilion G6-1d16dx Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Wireless Card Replacement: 2 단계, 이미지 1/1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Wireless Card Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/2 HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: 4 단계, 이미지 2/2
    • Unscrew the two captive screws using the Phillips #000 screwdriver.
    • The screws will not come all the way out; stop when you hear them click.
    • Unsnap the protective cover off of the device.
    • Locate the wireless card.
  5. HP Pavilion G6-1d16dx Wireless Card Replacement: 5 단계, 이미지 1/2 HP Pavilion G6-1d16dx Wireless Card Replacement: 5 단계, 이미지 2/2
    • Remove the two screws located on the corners of the wireless card, using the Phillips #000 screwdriver.
    • Slide the Wi-Fi card out of the socket.
  6. HP Pavilion G6-1d16dx Wireless Card Replacement: 6 단계, 이미지 1/1
    • Using your fingers, unsnap the coaxial cable wires from the wireless card.
    • Connect them to the new card based on the attachment points.
    • These points are indicated by numbered tabs. For example, wire #1 connects to #1 on the wireless card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shyanne Bolton
회원 가입일: 04/05/18
468 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 36
전체 시간: 1,494
