주요 콘텐츠로 건너뛰기
HP Pavilion G60-235DX Keyboard Replacement
필요한 것
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion G60-235DX Keyboard  Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion G60-235DX Keyboard  Replacement: 2 단계, 이미지 3개 중 3개
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: 3 단계, 이미지 1개 중 1개
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
결론
작성자
1다른 기여자 명과 함께
Gilbert Han
회원 가입일: 01/24/17
241 평판
안내서 2개를 작성함
Cal Poly, Team 10-5, Banghart Winter 2017 Cal Poly, Team 10-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G5
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 501
