주요 콘텐츠로 건너뛰기
HP Pavilion G60-247CL Fan Replacement
필요한 것
  1. HP Pavilion G60-247CL Fan Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Fan Replacement, RAM: 2 단계, 이미지 1/1
    • Locate RAM access door on the bottom side of the laptop.
  3. HP Pavilion G60-247CL Fan Replacement: 3 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 3 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 3 단계, 이미지 3/3
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  4. HP Pavilion G60-247CL Fan Replacement: 4 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 4 단계, 이미지 2/2
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  5. HP Pavilion G60-247CL Fan Replacement: 5 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 5 단계, 이미지 2/2
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  6. HP Pavilion G60-247CL Fan Replacement: 6 단계, 이미지 1/1
    • Gently lift the RAM stick up and out of its seat.
  7. HP Pavilion G60-247CL Fan Replacement: 7 단계, 이미지 1/1
    • Repeat the previous two steps for the remaining stick of RAM.
  8. HP Pavilion G60-247CL Fan Replacement, Screen: 8 단계, 이미지 1/1
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  9. HP Pavilion G60-247CL Fan Replacement: 9 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 9 단계, 이미지 2/2
    • Remove the seven Phillips #0 screws from the battery compartment.
  10. HP Pavilion G60-247CL Fan Replacement: 10 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 10 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 10 단계, 이미지 3/3
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  11. HP Pavilion G60-247CL Fan Replacement: 11 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 11 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 11 단계, 이미지 3/3
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  12. HP Pavilion G60-247CL Fan Replacement: 12 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 12 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 12 단계, 이미지 3/3
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  13. HP Pavilion G60-247CL Fan Replacement: 13 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 13 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  14. HP Pavilion G60-247CL Fan Replacement: 14 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 14 단계, 이미지 2/2
    • Remove the black wire from the top right corner by gently pulling outward.
  15. HP Pavilion G60-247CL Fan Replacement: 15 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 15 단계, 이미지 2/2
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  16. HP Pavilion G60-247CL Fan Replacement: 16 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 16 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 16 단계, 이미지 3/3
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  17. HP Pavilion G60-247CL Fan Replacement: 17 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 17 단계, 이미지 2/2
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  18. HP Pavilion G60-247CL Fan Replacement: 18 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 18 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 18 단계, 이미지 3/3
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  19. HP Pavilion G60-247CL Fan Replacement: 19 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 19 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 19 단계, 이미지 3/3
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  20. HP Pavilion G60-247CL Fan Replacement: 20 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 20 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 20 단계, 이미지 3/3
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  21. HP Pavilion G60-247CL Fan Replacement: 21 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 21 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 21 단계, 이미지 3/3
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  22. HP Pavilion G60-247CL Fan Replacement: 22 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 22 단계, 이미지 2/2
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  23. HP Pavilion G60-247CL Fan Replacement: 23 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 23 단계, 이미지 2/2
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  24. HP Pavilion G60-247CL Fan Replacement: 24 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 24 단계, 이미지 2/2
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  25. HP Pavilion G60-247CL Fan Replacement: 25 단계, 이미지 1/1
    • Remove the screen from the outer casing carefully.
  26. HP Pavilion G60-247CL Fan Replacement, Speakers: 26 단계, 이미지 1/1
    • With the battery and RAM removed, locate the hard drive access panel.
  27. HP Pavilion G60-247CL Fan Replacement: 27 단계, 이미지 1/1
    • Remove two 1.2 mm Philips#01 screws.
  28. HP Pavilion G60-247CL Fan Replacement: 28 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 28 단계, 이미지 2/2
    • After the screws are removed, slide the hard drive panel to right to remove it.
  29. HP Pavilion G60-247CL Fan Replacement: 29 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 29 단계, 이미지 2/2
    • Identify the three screws holding the hard drives cover in place.
    • Remove each screw using a #0 Philips screwdriver to reveal the hard drive.
    • This particular laptop does not contain a hard drive-- yours will.
  30. HP Pavilion G60-247CL Fan Replacement: 30 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 30 단계, 이미지 2/2
    • Locate the storage battery, next to the hard drive.
    • Genlty pop out storage battery with fingers.
  31. HP Pavilion G60-247CL Fan Replacement: 31 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 31 단계, 이미지 2/2
    • Locate the Wifi card cover panel, left of the RAM.
    • Using a Philips #1 screwdriver remove the screw holding the panel down.
  32. HP Pavilion G60-247CL Fan Replacement: 32 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 32 단계, 이미지 2/2
    • Lift up on the screw side to remove the panel.
  33. HP Pavilion G60-247CL Fan Replacement: 33 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 33 단계, 이미지 2/2
    • As the screws are removed the Wifi card will pop up.
  34. HP Pavilion G60-247CL Fan Replacement: 34 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 34 단계, 이미지 2/2
    • Remove Wifi card by pulling to the left of the laptop.
  35. HP Pavilion G60-247CL Fan Replacement: 35 단계, 이미지 1/1
    • Flip over to the top view
    • Remove five 1.2 mm Philips#00 swrews
  36. HP Pavilion G60-247CL Fan Replacement: 36 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 36 단계, 이미지 2/2
    • Using a spudger unclip the casing around all corners and edges.
  37. HP Pavilion G60-247CL Fan Replacement: 37 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 37 단계, 이미지 2/2
    • lift up the casing and remove to reveal the speakers.
  38. HP Pavilion G60-247CL Fan Replacement: 38 단계, 이미지 1/1
    • Remove highlighted 1.2 mm Philips #00 screw from right speaker.
  39. HP Pavilion G60-247CL Fan Replacement: 39 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 39 단계, 이미지 2/2
    • Using a spudger, remove the highlighted white wire.
  40. HP Pavilion G60-247CL Fan Replacement: 40 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 40 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 40 단계, 이미지 3/3
    • Using a spudger, remove both additional highlighted wires from the motherboad.
  41. HP Pavilion G60-247CL Fan Replacement: 41 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 41 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 41 단계, 이미지 3/3
    • Lift up and out each speaker from the base.
  42. HP Pavilion G60-247CL Fan Replacement, Fan: 42 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement, Fan: 42 단계, 이미지 2/2
    • Locate the fan in the top left corner.
    • Carefully disconnect the wire attached to the motherboard using your fingers.
  43. HP Pavilion G60-247CL Fan Replacement: 43 단계, 이미지 1/1
    • Locate the disk player in the bottom right corner.
    • Remove three screws using a Phillips #00 screwdriver.
  44. HP Pavilion G60-247CL Fan Replacement: 44 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 44 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 44 단계, 이미지 3/3
    • Slide out the disk player to the right.
  45. HP Pavilion G60-247CL Fan Replacement: 45 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 45 단계, 이미지 2/2
    • Gently disconnect the ribbon cable using an opening tool.
  46. HP Pavilion G60-247CL Fan Replacement: 46 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 46 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 46 단계, 이미지 3/3
    • Disconnect the wire connected to motherboard by gently pulling downwards.
  47. HP Pavilion G60-247CL Fan Replacement: 47 단계, 이미지 1/3 HP Pavilion G60-247CL Fan Replacement: 47 단계, 이미지 2/3 HP Pavilion G60-247CL Fan Replacement: 47 단계, 이미지 3/3
    • Disconnect the wire connected to the motherboard using an opening tool.
  48. HP Pavilion G60-247CL Fan Replacement: 48 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 48 단계, 이미지 2/2
    • Gently remove motherboard with fan from the shell.
  49. HP Pavilion G60-247CL Fan Replacement: 49 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 49 단계, 이미지 2/2
    • Flip over the motherboard to view the back side.
    • Remove four 1.6 mm screws with a Phillips #1 screwdriver.
  50. HP Pavilion G60-247CL Fan Replacement: 50 단계, 이미지 1/2 HP Pavilion G60-247CL Fan Replacement: 50 단계, 이미지 2/2
    • Gently lift out the fan.
결론
Haley Matthews
회원 가입일: 03/12/18
517 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G5, Covino Spring 2018 UMass Dartmouth, Team S4-G5, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 306
