소개
The battery may not have power. Over time the battery may get worn out or barely hold a charge if it is not plugged in. If the battery is not working and it needs to taken out, the following steps show how to remove it properly.
Turn your laptop over so the bottom is facing up.
Locate the battery latch and slide the latch switch all the way to the left.
거의 끝나갑니다!
To reassemble your device, line up the battery and place it gently on the metal prongs to ensure a stable connection.
결론
