주요 콘텐츠로 건너뛰기
HP Pavilion G60-630US Hard Drive Replacement
필요한 것
  1. HP Pavilion G60-630US Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion G60-630US Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion G60-630US Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Hard Drive Replacement: 2 단계, 이미지 1/3 HP Pavilion G60-630US Hard Drive Replacement: 2 단계, 이미지 2/3 HP Pavilion G60-630US Hard Drive Replacement: 2 단계, 이미지 3/3
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
    • Remove cover from the back of the laptop.
  4. HP Pavilion G60-630US Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove three 5.5 mm JIS#0 screws.
  5. HP Pavilion G60-630US Hard Drive Replacement: 5 단계, 이미지 1/1
    • Gently, slide the whole hard drive to the right with your fingers.
  6. HP Pavilion G60-630US Hard Drive Replacement: 6 단계, 이미지 1/3 HP Pavilion G60-630US Hard Drive Replacement: 6 단계, 이미지 2/3 HP Pavilion G60-630US Hard Drive Replacement: 6 단계, 이미지 3/3
    • Lift up on black tap attached to the hard drive to remove the hard drive.
결론
Nicole Welter
회원 가입일: 09/27/17
213 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 740
