주요 콘텐츠로 건너뛰기
HP Pavilion G7-2235DX Fan Replacement
필요한 것
  1. HP Pavilion G7-2235DX Fan  Replacement, Fan: 1 단계, 이미지 1/1
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Fan  Replacement: 2 단계, 이미지 1/2 HP Pavilion G7-2235DX Fan  Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Fan  Replacement: 3 단계, 이미지 1/2 HP Pavilion G7-2235DX Fan  Replacement: 3 단계, 이미지 2/2
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Fan  Replacement: 4 단계, 이미지 1/2 HP Pavilion G7-2235DX Fan  Replacement: 4 단계, 이미지 2/2
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Fan  Replacement: 5 단계, 이미지 1/2 HP Pavilion G7-2235DX Fan  Replacement: 5 단계, 이미지 2/2
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joseph Lampley
회원 가입일: 10/11/16
208 평판
안내서 1개 작성함
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 861
