주요 콘텐츠로 건너뛰기
HP Pavilion G7-2235DX RAM Replacement
필요한 것
  1. HP Pavilion G7-2235DX RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Before beginning, make sure the laptop is properly shut down and charger is detached.
    • Slide the battery release switch to the center of the computer to release the battery.
  2. HP Pavilion G7-2235DX RAM Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
  3. HP Pavilion G7-2235DX RAM Replacement, RAM: 3 단계, 이미지 1/2 HP Pavilion G7-2235DX RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
  4. HP Pavilion G7-2235DX RAM Replacement: 4 단계, 이미지 1/2 HP Pavilion G7-2235DX RAM Replacement: 4 단계, 이미지 2/2
    • Slide the cover towards you, then pull up to remove it.
  5. HP Pavilion G7-2235DX RAM Replacement: 5 단계, 이미지 1/2 HP Pavilion G7-2235DX RAM Replacement: 5 단계, 이미지 2/2
    • Locate the RAM card and the two prongs holding it in place.
  6. HP Pavilion G7-2235DX RAM Replacement: 6 단계, 이미지 1/1
    • Using either your fingers or two metal tools, push outwards on the two prongs until the RAM card pops out.
  7. HP Pavilion G7-2235DX RAM Replacement: 7 단계, 이미지 1/1
    • The RAM card can now be pulled out at a slight angle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dante Mugnaini
회원 가입일: 10/13/16
219 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 393
