주요 콘텐츠로 건너뛰기
HP Pavilion G7-2289wm Fan and Heat Sink Replacement
필요한 것
  1. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Optical Drive: 2 단계, 이미지 1/1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 3 단계, 이미지 1/2 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 3 단계, 이미지 2/2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
  4. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Pull the edge of the service cover toward you to remove it.
  5. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 5 단계, 이미지 1/1
    • Disconnect the hard drive connector cable from the motherboard.
  6. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 6 단계, 이미지 1/1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  7. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Keyboard: 7 단계, 이미지 1/1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  8. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 8 단계, 이미지 1/3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 8 단계, 이미지 2/3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 8 단계, 이미지 3/3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  9. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Fan and Heat Sink: 9 단계, 이미지 1/1
    • Remove the three screws that hold the keyboard palm rest in place using a Phillips #0 screwdriver.
    • Lift the palm rest up and out.
  10. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 10 단계, 이미지 1/3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 10 단계, 이미지 2/3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 10 단계, 이미지 3/3
    • Remove the wires attached under the keyboard.
  11. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 11 단계, 이미지 1/1
    • Pry open the bottom of the laptop by using the opening tool to open it up. Do this around the entire outer edge of the laptop.
  12. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 12 단계, 이미지 1/3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 12 단계, 이미지 2/3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 12 단계, 이미지 3/3
    • Remove the screw that holds the motherboard in place.
    • Remove the wires attached to the motherboard.
    • Unplug the laptop fan.
  13. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: 13 단계, 이미지 1/1
    • Remove the four screws that hold the fan and heat sink in place.
    • Remove the entire heat sink from the laptop.
결론
Clayton LaBrecque
회원 가입일: 03/19/18
171 평판
안내서 1개 작성함
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 UMass Dartmouth, Team S8-G1, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 451
