주요 콘텐츠로 건너뛰기
HP Pavilion G7-2289wm Keyboard Replacement
필요한 것
  1. HP Pavilion G7-2289wm Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  3. HP Pavilion G7-2289wm Keyboard Replacement: 3 단계, 이미지 1/3 HP Pavilion G7-2289wm Keyboard Replacement: 3 단계, 이미지 2/3 HP Pavilion G7-2289wm Keyboard Replacement: 3 단계, 이미지 3/3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
결론
Ryson Smith
회원 가입일: 03/19/18
636 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 UMass Dartmouth, Team S8-G1, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 194
